If you don't want it, just leave out the cap.
You can use a 3-position mini-toggle as the pickup selector like that, but it must be an on-on-on not an on-off-on, and it's best to connect each of the pickup black wires to both sides of the switch, like the blue wire is.
Thanks for the help
With this type of switch it also saves working out which way the offset is in the middle position .
It makes such a difference to have someone step in and help with accurate advice. I ok at painting by numbers approach with this type of stuff but crap at trying to figure it out on my own
Cheers again
