EMG pickups pt2. Can I ditch all that solderless stuff and use regular pots/switches?
axisusaxisus Frets: 28397
I'm getting fed up with all that solderless garbage, With EMG active pickups can one dump all that stuff and just solder in some regular pots, and a regular switch?
What I do know with my stuff now is that the volume pot is definitely buggered. Honestly I'd rather ditch all that stuff and just wire them up in a regular way - one wire to switch, one to ground and presumably one to battery.
Would I need 25k pots?
  • Yes, just use 25k pots
  • ICBMICBM Frets: 74493
    Yes, yes, and yes you should.
  • FelineGuitarsFelineGuitars Frets: 11978
    It is much easier I find with soldered pots . We keep the 25k ones in stock and CRL switches
    Even the connection of the battery is easier in my opinion
  • Yep - that's what Feline did with the EMGs in my Performance
  • axisusaxisus Frets: 28397
    Great! How do I order? I can't see them on the Feline website. I'm after 1 vol 1 tone and a 5 way switch.
    Can anyone advise me on wiring the battery wires from the pickups? Presumably you wire so that they are only active when the guitar is plugged in?
  • Danny1969Danny1969 Frets: 11014
    edited October 2020
    The red battery lead is connected directly to the red wires of the pick ups ..  the battery is switched into circuit by inserting the guitar lead into the stereo jack which shorts the battery ground to guitar ground
  • FunkfingersFunkfingers Frets: 15276
    50k and 100k pots are acceptable for some applications.
    phone me or PM me
