Granted it is pricey I think that even the tester set I bought was something like £40 but there’s enough to do
at least 20 necks
Both give a matte type finish (although you can add 50-60% thinners to tru oil, coat lightly with no wipe off to build shiny layers and then buff later.)
Mahogany will want grain filler, with maple none and a first coat with wire wool should do to add some slurry in the pores. Thereafter wipe on thin and wipe off shortly after and hang up. If you get dull looking areas then wirewool them lightly before next coat, otherwise no need to sand between coats, a rough rag for application will do.
I've been trawling ebay for things thinking about a partsocaster.
