Hi chaps, I’m going to ask here about this one.
Many years ago, I slotted a Bandmaster Reverb chassis into a 2x10 combo cab and blackface modded it. At the time I wanted something spanky and loud to gig fairly big rooms with, so it got 7581A’s and Eminence Rabin Cajuns.
I sold the amp about 8 years ago, but this week I got it back. I’ve looked back at my work, and I’m quite pleased with what I did with it originally. However, times have changed and I’ve got a bit more sensible, so I’m going to try to make it a but softer and quieter to perhaps get the sweet spot down to where I could use it in smaller rooms.
I’m swapping out the Eminences for something more vintage with less sensitivity and I’ve fitted some small bottle Philips 6L6WGBs.
The one thing I didn’t change years ago were the values of the dropping resisters under the cap can. I kept the 4.7k + 1k combination for max preamp voltage and headroom. I’m thinking I could change these for the 10k + 10k combination shown on the blackface Vibrolux schematic, but I’m hesitating as I’m lacking a little confidence to do it, as I don’t know if I can or should with this power transformer.
Basically, can I do this, and would it achieve what I think it might?
cheers,
Rob
If you need noticeably less power you need an attenuator or a post-PI master volume.
I’ll get the iron warmed up now!
With lockdowns and having more time in my hands I’ve created a nice workshop space and intend to get back to more of this stuff. I must say though that it will be a while before I attempt a scratch built Trainwreck! I have followed your threads with interest for some time.
Cheers,
Rob
Rob
As for dropping resistors, as a quick test I stuck a 25k linear pot in the position after the phase inverter on one amp and was able to modify the value on the fly to see what it did to the tone, feel and clarity of the amp, its pretty interesting to do , subtle effect - but higher voltages definitely sounded brighter and clearer, which on that amp was the right thing, but for others you may want to shoot for lower voltages, you really need a higher wattage pot than I used for this, but you could put resistors on a switch too.
Lowering the voltage of a gain stage will make it easier to distort that stage, especially if it is bypassed, as well as add more harmonics
Rob
B+1 is 444v.
B+2 is 442v
B+3 is 434v !!!
B+4 is 400v !!!
Whilst the first two are ballpark Bandmaster Reverb (what this is based on) and also silverface Vibrolux Reverb (what I’m aiming at). The second two readings are a lot higher than the Bandmaster schematic with the stock value dropping resisters of 1k and 4.7k respectively. I don’t really understand why they are so much higher than spec, my B+3 and B+4 should be 395v and 360v respectively with the dropping resisters I have as stock.
I may have to experiment here to see how much I can get these down to where they should be.
Thanks for listening,
Rob
Your 1K resistor has 8mA flowing through it (8v drop/1000r)
Your 4.7k has 7.25mA flowing through it 34v/4700r
not looked at the schematic, but to me it doesnt look like you have anything connected to B+3??
