Fender use two (or maybe more) types of "Kluson" tuners - Gotoh SD91s on USA and Custom Shop models, and Ping on the Mexican models. I'm not sure about Squiers.
Both types are fine, but the Ping ones are cheaper.
https://www.kluson.com/kluson-modern-bolt-bushing-to-vintage-push-in-cosmetic-adapter-kit-for-vintage-stamped-steel-series-tuning-machines-details.html
If they still utilise the push in 'bush' that fits around the string post then you should be fine
IMO nothing wrong with a good Gotoh vintage style
I will check for the nut as soon as the guitar arrives which will hopefully be tomorrow
Wicked thanks mate
With those nuts it makes the hole wider - Hence the bushing conversions required
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
