This is something I've been confused about for a while. I see lots of people saying that the string tension on one guitar is different to another, when they're the same scale length. I would have thought that if the scale length and string gauge is the same, the tension would have to be the same or the pitch would change?
The only thing I can think is that they saying it's easier to bend the strings, because there's more string behind the nut or bridge to compensate. I'm sure I'm overlooking something obvious, would be grateful if someone could explain.
The *perceived* tension can be different depending on the setup, the type or absence of tremolo system etc..
But yes, in principle it is the perceived differences rather than actual differences in tension.
Raising the tailpiece on a Les Paul just a bit makes for easier bending.
