[This space for rent]
There’s a version of the Schaller Megaswitch which does it too, which is simpler - the E model. I’m not a huge fan of the feel of them and I’ve seen a couple of reliability problems with them, but they’re not bad.
The switching with EMGs is always the same as for passive pickups.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
89 spec
SA spec
Am I missing something?
I suppose an email to EMG technical support may be the only option.
In theory, it ought to be possible to add a resistor via the shunts on the push-pull mode switch for the -89. I have no idea what values would bring the -89 output down to -SA level.
My own solution to this dilemma was to use an EMG-HA in the bridge position and dial in an -SPC mid booster to get humbuckeresque sounds (and power). Very Gilmourish.
The superswitch and Seven Sound suggestions depend on permanently soldered connections at the selector switch end. Solderless™ wiring harnesses will require some modification.
