10-16” compound neck with a tune-o-matic bridge?
Can this be done? I’ve done some reading and it looks like ideally I’d have an 18” or 20” radius bridge, but tune-o-matics seem to mostly be 12” (I’ve found a 14” too).
Would filing the slots deeper on the middle four saddles work? Will it look messy?
I’ve seen the Hipshot Baby Grand and that would be a fun one to use, but that’s 11.5”.
  • ICBMICBM Frets: 73077
    Ideally you want the bridge radius slightly flatter than the neck - of the the body end on a compound radius - so 20” would be about right. But in practice there’s not a huge difference, especially in the flatter radii - I would try it first before deciding it needs altering. If it does then fairly minimal deepening of the grooves for the middle strings should do it.
  • Winny_PoohWinny_Pooh Frets: 7899
    edited November 2020
    I've modded many saddles, pretty easy.
