https://youtube.com/@alexfarranguitar
https://instagram.com/alexfarranguitar
Modern ones have angled neck pockets
That said I'd want to try the new AM Pro for its updated trem and series/parallel circuit - particularly if I hadn't had a JM before to get any preconception.
@ThePrettyDamned is spot on re setup. They're not actually difficult or finnicky once you get the geometry right, but that needs a chunky shim in the neck pocket. Combine with a Staytrem bridge and you have one of the best trem systems ever made imo.
I spent less than 1k on my MJT build and got exactly what I wanted with literally zero compromise. But I was very sure of what I wanted.
I’ve built a couple of parts guitars before using MJT bodies and necks, but this time around I definitely just want to get something ready to go from the box.
@stickyfiddle funny you mentioned the new Am pro series as I was just watching a video on those. They look great! but I’m still leaning towards the American original.
Any thoughts on American original vs American Pro II? I notice they are similarly priced and wonder if there’s a benefit one way or the other.
APro2 = more modern, urethane finish, series/parallel switch, fancy modern trem that dives lower, can be had with maple fretboard headstock-adjust truss rod
For me the AO is 99% of the spec I went for myself when I built my MJT.
