Design Example
To design the power supply we need to know how much average DC current the amplifier circuit will draw. The preamp stages will normally be single-ended (class A) so they draw constant average current. If the preamp valves are ECC83 / 12AX7s then they will usualy be biased around 1mA per triode, or less. You can work this out from load lines.
If the output stage is class AB (e.g nearly all push-pull amps) then its current will increase with signal level. The output valves will therefore usually be biased to around 70% of the data sheet max anode dissipation, thereby allowing some power headroom, so they don't red-plate at full drive.
Let's suppose a 50W amp uses three ECC83 / 12AX7s and a pair of EL34s.
The preamp valves will consume around 6 x 1mA = 6mA (there are two triodes per bottle, remember).
The EL34s are rated for 25 watts maximum, so they will probably be biased around 0.7 x 25W = 17.5W. However, we should work with the maximum average figures, i.e. full drive when the average dissipation increases to 25W. Thus if the raw DC supply voltage is 400V then they will each consume about 25W / 400V = 62.5mA, or 125mA for the pair.
The data sheet suggests a screen-to-anode current ratio of 6.5, so we can expect the screen currents to amount to 125 / 6.5 = 19mA for the pair.
The total for the whole amp is therefore 6 + 125 + 19 = 150mA.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Nice guy, met him in York once to pick up something I'd bought form him - I forget what...
R.
Eqd Speaker Cranker clone
I used this calculator to get the current draw for 1x12AX7 and 1x6L6GC assuming the PT is working at 300-0-300, and it gave 96mA so it looks like it will work. How far is it normal for the voltage to be pulled down without caning the transformer? It's a fairly chunky unit as you can see from the pic below.
7.6A is way too high for a filament winding in a transformer that size - it won't be rated for anything like that, more likely about 3A max.
The transformer primary has an old typewritten note stuck to it advising you how to connect the two primary windings in series for 210-250V or in parallel for 105-125V.
Those output current readings were done with the mains power on for a couple of seconds at a time. I wanted to see how much current would pull the outputs down to 6.3V or 5V. I'm only going to be running a 5Y3 (2A of 5V filament current), a 12AX7, and a 6L6GC (combined filament current 1.2A), so I'll drop the voltages to bring them into range.
My main concern is whether the HT has enough beans to run the 6L6GC.
I think it should probably be OK - that size of transformer looks like it should be for something like a 2-EL84 15W amp in near-Class A, so a single-ended 6L6 won't pull any more than that.
or if you want to try high spec
from a small maker then AskJanFirst in germany is particularly good.
