The tapped position is apparently hotter than vintage Strat but to me it sounds exactly what you want - position 2 sounds like normal position 2 on a Strat.
http://www.buildyourguitar.com/resources/lemme/ - useful resource on Single Coil Resonant Peaks.
The other thing to remember is that even if you tune the treble response to make it more "humbucker like" - it still won't feel like a Humbucker because Single Coil pickups have a wider dynamic range or to put it another way, Humbuckers impart a degree of compression.
Plus they're truly great guitars (and very cheap second hand..)
https://www.alchemypickups.co.uk/single-coils
one thing I’ll say is Jack provides great service, is happy to work with you and offers 12 month return or replacement if you’re unhappy
I still get a decent sound that I can live with in position 2, although there will always be a difference compared to the underpowered (IMHO) regular strat bridge pickup.
The bridge pup is hotter but its connected to a no load tone control that lets you tone it down without sounding dull or muddy and it sounds, well a little bit HB like but with the tone full up it's a Strat. But you still get all the classic Strat tone goodness. It works really well and if you get a chance you should definitely look for one to try out.
" Fender introduced the Delta Tone in 1997, and the first guitar to receive this new feature was the American Standard Stratocaster. ... The Delta Tone wiring features a no-load tone control for the middle and bridge pickups, great for producing just a bit more midrange and hotter output from the Stratocaster. "
https://www.premierguitar.com/articles/The_Fender_Delta_Tone_System_Part_1
https://www.premierguitar.com/articles/The_Fender_Delta_Tone_System_Pt_2
