I've also got a Marshall ED-1, mint condition that you could have for £33 delivered....
Also the Mooer Yellow Comp is supposed to be based on the Diamond Comp - which has a great reputation.
The Joyo JF-10 isn't supposed to squish too much
The Orange Squeeze?( as I think the Joyo and Mooer are SMD)
The Orange Squeeze is a pretty subtle compressor - I wouldn't bother with a blend, I prefer a 1n60 diode to the one they recommend... I think using some tantalum caps can help (I'll see if I can find the part numbers).
Basically there's an interaction between the 2n5457 matched transistors and the 4558..
I think it's a great design for not modding but nailing. I think Jon Patton mods it with a fine control pot on the trim pot, so the bias trim (10k) has a 2k pot attached for tuning when you change guitars..
But importantly, this'll fit in a 1590a.
