I have a Gibson Les Paul Special that I bought 45 years ago. The
original control plates got damaged at some point long ago and I had
replacements made from stainless steel sheet. These are very nice but if
possible I'd like to replace them with something closer to the original.
I don't think that I can get direct replacements as I'm not sure the
cavities on this are the same as an other guitars. I'd certainly buy
them if they would fit. I'd be happy to make some but I have struggled to locate the material.
Does anyone know where I could get some 2.5mm, single ply, rigid, black plastic? Dark brown would do at a push.
TIA
The cover for the pots is a rhombus with rounded corners.I also have a Standard and the cover on that is a similar shape but it doesn't fit.
The switch cover for the special is racetrack shaped.
Thanks for the info on axiom. I didn't know of them but I'll definitely be in touch with them.
I'm glad I asked on here now!
Thanks for the help. I tried mine again and they don't fit. It's only a midges but the plate won't sit flush in the recess. The standard plate is just a tad too large on two corners. If all else fails I can get a couple of standard plates and trim them down using the steel ones as templates.
