Quality - define quality. Some people want nitro. Some want shiny thick poly. Some want exotic timber. In this context my definition is “fit for purpose”
So, so far, I love it around 75%, but it definitely needs some tweaks then I think it will be a real long-term guitar.
Probably.
Main thing is unless you are a pro and have all the tools have a proper setup done. Assuming everything else is good (parts and fitting), this step really takes a guitar to the next level.
I've done the setup myself and I'm happy with it.
I recently got a nitro green body from @GoldenEraGuitars and a reverse neck from @GSPBASSES with a set of personally wound @Van_Hayden pickups and which, because I'm lazy and shite, put together by @IvisonGuitars and I've gotta say it's pretty much an amazing second guitar to switch from No1.
Overall, partscasters are a brilliant alternative to custom shop guitars, but I think you need to know exactly what you want and need in a guitar
Partscasters used to appeal to me so much because there's no compromise on spec or quality of parts, and normal Fenders are just boring. However since I realised Charvel do the San Dimas hardtail line that pretty much has everything I want from a strat (HH, hardtail, compound radius neck, rolled fingerboard etc), I'll probably just go down that route next time. Made a massive loss on my last one and parting out is a ball ache.
Strat. Started as a Squier 20 years ago, and currently has its 5th neck (Musikraft via MJT for finishing) and at least that many pickup changes, but I have it about perfect at that point. It’s honesty the best non-vintage Strat I’ve ever played.
La Cabronita - essentially a parts build, though finished and setup by WezV of these parts. This was about getting a spec Fender didn’t make (big neck with rosewood board, Thinline body without f-holes and with 60’s style binding). I occasionally struggle with the neck profile but it plays fantastically, looks incredible and sounds massive. Very happy overall and it’s (almost) completely unique
Jazzmaster - full MJT build with everything specced exactly as I wanted. Before the American Original series it was the only way to get vintage looks with 9.5 radius and taller frets outside the CS, except for this one I have Mojo pickups and an original 60’s tort guard. It’s great.
So basically “partscasters yay”, provided you have a good handle on what you want.
Yes you can suggest they are ‘copies’ - some suggest they are fakes (let’s avoid that argument, though) but in my view they are just as valid and just as great as other ‘copies’ such as the jap Les Paul clones or those vintage guitars reworked into things they never were.
A partcaster can be wonderful. I have several and they are incredibly useful tools. Imho, all are better than an off the peg guitar because I couldn’t buy the same spec from Fender.
Darren made the neck to fit the body so I guess it’s half partscaster half custom build. But 100% awesome.
It's bits of wood screwed or glued together. If it's done correctly, it won't be any worse than one from a factory.
If you are using an off the shelf neck and body at worst you can expect the finished guitar to be about as good as an average US Standard, while at best it could stand toe to toe with a custom shop instrument, though this is by no means guaranteed.
If you want to be sure of getting custom shop quality you need to do what @skippy76 did and get at least the neck fabricated by a specialist. Money spent on finishing and hardware will only get you so far.
Also, it goes without saying that if you don’t have the skills to set up the instrument yourself then getting it done by someone who knows what they are doing will be money well spent.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
Chambered ultra light body
Gotoh 510 Tremolo
Kinman / Ilitch noise cancelling pickups
7-sound mod
come to think of it, guitars by companies like SVL, Anderson, Suhr, Tyler etc are basically well put together partscasters, except that the makers have now created a reputation for themselves - and their name on the headstock actually bolsters the value of the instrument.
With a great guitar technician to do a fabulous set up, you can achieve the same thing at 1/4 to 1/3 the price.
