Greetings folks,
A brief moment away from building the doubleneck, and Flying-V kit, here is my attempt at a Tyler Guitars Burning Water/metallic Jim Burst finish. Yes, it's not to everyone's taste. No, it's not the easiest finish to take on. Yes, I've spent a small fortune on nitrocans from
@SteveRobinson ; for this
And lastly, no it isnt finished yet.
The base guitar was a Squier Silver Series that had previously been finished in a non-hardening black gloop. On top of brick-hard something. I ended up rasping most of the old finish off. Underneath was some wood of a fairly soft nature. Paler than alder, I think. And an uneven 3-piece body. There were also several really odd marks all over the body - like something had used the pointy end of a Phillips screwdriver to take pot-shots.
Anyway, the body was sanded back, filled (not very well), and sprayed up through the coats which would then be randomly sanded back through to give a sortof wood grain effect of multicolour.
Sealer, white, blue, silver (mopped off when still not dry to give a crinkle PRS effect), more white, blue, yellow, red.
This was left hanging for a couple of months to harden, and then have at it with some 240grit to rough-out the blotchy sand-through.
When I was roughly happy with the pattern, I smoothed the edges with 320 then 400 grit.
The Jim Burst part is a metallic pink/redd/blue fade down the body that is then selectively sanded away to give another layer of effect.
So, I masked off a portion and did another black-silver-clear colour spraying.
I now need to wait for the second-stage metallic portion to harden before selectively sanding away again, and then clear coating all.
Testing abrasive grits, settling on 240. Roughly scribbled out areas for sanding too.
https://i.imgur.com/UMUKcUc.jpg
Rest of the body sanded through and finessed a little with 320/400 grit, and with the next silver coat on
https://i.imgur.com/Gux06GS.jpg
Masking tape removed
https://i.imgur.com/NALUNQV.jpg
Close up of what happens when you spray tired, get a run and try to wipe it away. Yes, I know, lesson learned!
https://i.imgur.com/0l0xxEX.jpg
https://i.imgur.com/SbzCE0c.jpg
However, re-did the arsed-up portion, and this is now hanging up, drying. The edges of the metallic will look better once softened up a bit.
https://i.imgur.com/beCNDsh.jpg
https://i.imgur.com/bSucF7b.jpg
And lastly, why spraying outdoors in central Scotland isnt always a good idea. A sacrificial insect, gave it's life, forever to bond with the guitar.
https://i.imgur.com/hViAPoF.jpg
Thoughts, comments and suggestions welcome as always,
Adam
Thank you most kindly for the comments - and @MattNovak I try not to do the math on these things!
Ive found the hardest bit has been leaving the finish long enough to harden so the abrasive doesn't gum-up whilst sanding through, and knowing when to stop sanding the coarser grits before finessing. A bit of trial and error.
Next time, a Shmear!
i do love a burning water finish.
Im overall happy with the result, though there are certainly some areas that might have been better done. Ive learned a few things for the next attempt - using thinner masking tape and not spraying a 'ledge', ensure all layers are flat before continuing, start with 240grit minimal before sanding back, and dont worry too much about perfection.
I've sanded through to the wood in places, but not sure it's a huge issue here.
So, here are the photo's of the first 2 clear coats.
https://i.imgur.com/A1Iidmo.jpg
https://i.imgur.com/7e87aTH.jpg
https://i.imgur.com/pDUFGpO.jpg
https://i.imgur.com/A3rJGZR.jpg
https://i.imgur.com/zu9V7tO.jpg
https://i.imgur.com/7BjJWuq.jpg
Cheers for viewing,
Adam
Also, finished the neck too. Shaved off the shoulders a bit to more of a 'V', and rolled the edges. Though i might have gone a bit overboard there. Finished in several light coats Osmo Poly-X and a very light waxing.
Adam
looking forward to seeing the finished masterpiece
