Can anyone help me with a telecaster custom copy which ive spent all of yesterday to sort out with no joy.
All works as it should apart from when either of the volume controls are turned down to zero there is a loud earth like hum ( like the lead is unplugged and held ).
If I touch any of the metal parts there is only a very slight much improvement.
I've checked the earth wire to the bridge and it's fine and tried patching leads to different parts with no joy.
Not sure if it's a wiring as it looks fine or a faulty part.
Any help as always would be appreciated.
Swap the connections so the pickups and tone controls are connected to the outer terminals and the switch to the middle terminals.
Also check the ground connections are all properly connected at the switch, it looks a bit of a mess - although hard to see in the pic.
Thanks as always to ICBM.
