Don’t know if this is the dreaded Rick pickup degeneration or a faulty pot so hoping one of you gents can help?
Probably need the knowledge of
@icbm as our resident Rickenbacker guru.
Plugged in my 330 this evening and the bridge pickup was quieter and for lack of a better term: less alive. It sounded like it was going through a really squishy compressor, almost as if the volume started soft as it was picked and then swelled. Very odd. Tried other guitars, different amp, lead, the lot...all fine, except with the 330. Also noticed the volume pot seemed to peak around 7 when in the middle setting, not sure if that’s a symptom?
Keeping my fingers crossed this is actually an easy fix.
also, is it like it with just the one pickup selected?
I’ll try the tone pot test later @ICBM and will report back.
Failing caps can do weird things.
It is now working ‘fine’, tone pot worked as normal and bridge pickup volume is back where it should be. Still got the slight volume swell on the middle setting on sliding the bridge back from 10 but none of the ‘squishyness’ to the sound that was there yesterday on either setting, or the blooming of notes on the bridge pickup.
