I've pretty much made a complete swap at home to using rechargeable batteries in everything around the house, from TV remotes to my stepdaughter's lamps & toys.
Was looking at rechargeable 9V batteries for my wah & tuner, but I couldn't find any mAh info on a standard lithium type to compare it to the various rechargeables that I found.
Anyone using them? And if so are they any good, or do they need charging every other day?
I'm probably the only member of this forum mentioned by name in Whiskey in the Jar
They're just cheapo EBL 600mAh PP3s and they've been going for about five years quite happily.
I usually use them in a Marshall Drivemaster or a Reflector reverb pedal and they usually last around 6-8 hours playing time. I have four in total so always have spares ready to go in the charger, which is on pretty much whenever my laptop is plugged in as it's on the same gang lead.
I'd say they've saved me a small fortune, as I really want to just bung an always-on pedal on top of the amp without faffing with mains adaptors etc.
Most Nickel Metal Hydride PP3's are about 2- 300 mAh.
I tend to run most pedals from a mains adapter.
I think rechargeable 9V batteries are at least the correct voltage, roughly
8.4v
Whereas
AA and the other 1.5v type rechargeables are 1.2v
(although there are some now that are 1.5v lithium from a new brand)
AFAIK most digital kit allows for this, but worth realising
