Don't forget that your string heights are not usually equal. Bass side usually a smidge higher. The flatter radius helps get a better graduation on this increase.
Also the strings don't follow the radius of the board unless its compound radius... because of the increasing distance between the strings.
The geometry is not as simple as saying the bridge should match the fretboard radius
And you can always get the nut files out to tweak as needed
Instagram
