Drill proper clearance holes of fender bodies
I find this "issue" on many Fenders, basically the neck screws are NOT supposed to "bite" the wood in the body. This is preventing a tight fit between body and neck. Who else drill those holes?
Discuss!
  • ICBMICBM Frets: 73105
    That's correct. I can also see you're turning the screws backwards at first to find the correct thread in the neck - this is extremely important, and a lot of people don't do this, especially if they're using a power screwdriver... it's the easiest way to strip the threads. I never use one for this sort of job.
  • SteveRobinsonSteveRobinson Frets: 7129
    Every time. I have a stock of 4.5mm bits just for that purpose.
  • dchwhitedchwhite Frets: 182
    How funny - I was about to ask this exact question as I have a Tele project I'm trying to complete, and can't get the neck and body together without leaving about a 1-2mm gap between them. Thank you - I don't even have to ask what size bit to use!
    Stonevibe: 'The best things in life aren't things'.
    Trading feedback: Previous (+18) and Current
    You are right, that's a little detail but I like to do it every time. I also prefer to take my time and do it manually so that I can feel how loose/tight the screws are.
    That's exactly the risk, not being able to tight neck and body together, especially if they come from different guitars. Drill the body holes and it will be fine!
