Looks to be decent and straightforward, and pretty good value.
Thanks for all the steering - as mentioned above, I guess I will not know until I try...
I have a Thalia and while it looks great, I find it to be quite bulky and difficult to move around. There is also something quite unpleasant about doing bends or vibrato with it, causing a nasty scraping sound as the strings move. This is because they use a very hard material for their fret pads, whereas other capos on the market tend to use a softer rubbery material which allows the string to glide more easily. I only use it if I know I'm not going to be moving it around very much and if I'm not planning on bending. IMO it is a lot of money for something that doesn't perform as well as the others - a little bit of style over substance. Worth mentioning though that I have a very early one and they may have improved the design since then.
Personally, I wouldn't stay at a gig if the capo used was anything other than a Shubb.
Slim and light, and easy to move around. I also like being able to determine the tension.
Thanks for the guidance.
