Brass/bronze packing washer for router bit bearing?
SteveRobinsonSteveRobinson Frets: 7129
I need to pack the bearing by about 2mm so more of it is against the template.
Does anyone know a source of suitable washers? I/D is about 4.6mm
  • GSPBASSESGSPBASSES Frets: 2357
    Surely if you’re trying to put that angle of cut round the headstock then you don’t need a template as the headstock itself becomes the template. Or is the template a different shape to the headstock so you’re just making it look pretty.
  • SteveRobinsonSteveRobinson Frets: 7129
    Yes the template is a different shape, I'm cutting the chamfer on an Epiphone style "batwing" headstock
  • WezVWezV Frets: 16981
    I think I would hand carve a chamfer that size
    You're probably right. It's much safer too, one slip of the bit and it could be game over for my guitar neck.
    I was aiming for a nice clean edge which the router would give me but TBH no Epiphone I have ever seen has a tidy carve here.
  • ICBMICBM Frets: 73104
    I think that probably speaks for itself about the accuracy of routing it too! Since I'm sure it would have been done like that at the factory.
    a good carving knife will give just as clean a cut as a router.  but even  if cut with a rasps, files or abrasives, it can still be be sharpened up with a small scraper if needed
    Most of the epi's look like they have lost a bit of definition from sanding anyway
  • paulnb57paulnb57 Frets: 3112
    Couldn’t you stack two bearings on a longer screw?
    No because the shaft that the bearing runs on is only about 3mm long. I suppose I could use a sleeve if I had one with the correct o/d and i/d but it's a long shot!
    I reverted to Plan A and used a sanding drum freehand in an electric drill. It worked okay I think, I'll be able to adjust it a little before painting.
  • PeteCPeteC Frets: 409
    Ah! ignore my question on your other thread.  Looks fine..
    Looks fine to me. Maybe that is actually how they did them at the factory after all...
    I suspect it is.... they would have had a few big sanders that could have done it
    edited December 2020 tFB Trader
    Thanks. Yes given the inconsistency of the originals I think it probably was.
  • Looks good to me too.  And a lot safer than using a router.
    ...and a lot more satisfying to use "hand" tools too.
