bear in mind, it does NOT change the order of the contribution of the power amp and speaker those are still going to appear last (there are options like micing and applying effects such as delay to the mic signal and running that to console)
There are some fx loops that allow for parallel signal routing (the loop's effects are parallel to the straight amp signal for a wet/dry type system) though this tends to be more common in bass amplification
Personally (and this will vary WIDELY, so I'm not saying it's a better system), I tend to try to get my tone as early in the signal chain as possible and then special effects are applied to that.
