New Pickguard and Shielding
I bought a new pickguard to replace the one on my Classic Vibe Jazzmaster and was wondering about the shielding (and also hoping the holes line up).
I'm a complete novice at this so any guidance would be great. Do I need to cover the back of the pickguard in copper tape?
The new one just has a small silver strip (aluminium tape maybe) over the tone pots and jack area and nothing else. I believe the inside of the cavities have the Fender black paint stuff for conductivity.
Also, what exactly is grounding? I have to make the wire touch the bridge screws or something?
  • ICBMICBM Frets: 73157
    The shielding should really cover all the ares where there is wiring underneath. It's not necessary elsewhere.
    The bridge should already be grounded, it's usually done with a wire trapped under the treble side 'thimble' insert.
  • thefezthefez Frets: 131
    Ok thanks.
    I guess if I'm just taking the bridge in and out only to remove the pickguard then it should still be grounded when I put it back in.
    Yes, it connects to the thimble in the body not the bridge itself. You'll see the wire when you take the pickguard off.
