Changing strings in the cold
scrumhalfscrumhalf Frets: 11684
I have to change strings on a few guitars and my heating is generally off during the day until late afternoon unless it's really cold.
Is there any downside to changing strings in a cold room? I will mostly be using D'Addario 9-42 and 9-46 sets.
  • It's absolutely the best time to do it. It hurts less when you stab the end of your fingers if they are mostly numb to start with.
    6reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • SassafrasSassafras Frets: 30358
    Cryogenically treated strings apparently last longer.
  • sev112sev112 Frets: 2988
    As the room temp subsequently increases, the strings will expand, making the longer, and pitch will reduce
    except, so will the neck expand
    and if that expands less than the strings expand you would think that would increase the tension and the pitch will rise
    except the string runs through the nut and is not fixed, so maybe nothing changes at all
    what do I know, I’ve drunk too much wine ;) hic
  • Isn’t the downside of changing strings in a cold room....just being cold ??
