Vibrating and buzzing 5f1 clone
Hi everyone,
My 5f1 Danplifier is vibrating a fair bit, there's at least two different resonances I'm picking up. I'm pretty sure one is a valve and the other is something chassis related or something else.
I'd really appreciate some help on the best way to go about trouble shooting the problems.
Many thanks
Richard
  • ICBMICBM Frets: 73158
    Basically you need to keep it vibrating - guitar feeding back, someone else playing, or a looper pedal, if you don't have an audio frequency signal generator - and poke around until you find what stops it. If it's inside the chassis you of course need to do it with the amp live, so use something insulated like a chopstick...
  • Rich210Rich210 Frets: 577
    Cheers @ICBM ; I'll  try that. When I do find what's causing it have you got any recommendations of materials to have to hand that might be useful for dampening etc.
    That depends what's buzzing!
  • 4114Effects4114Effects Frets: 3131
    Hi Rich. Drop me a PM and I'll see if we can track it down. Usually a simple fix.
    @4114Effects pm incoming  :)
  • PeteCPeteC Frets: 409
    Probable suspects are valves first - so try substituting each in turn , and then possible transformer lamination rattle ?
    Thanks Pete,  I had intended on having a look today but I got distracted in the studio playing rather loud
