I won’t name names or go into specifics but I’ve had an issue with an instrument and I’ve now got another. I want to ensure I give everyone the benefit of the doubt and not let my initial reaction get the better if the situation, so thought I’d share here and you can then tell me if I’m being unreasonable or just expecting to much.
So like I said I have this instrument, on day one I notice a slight very tiny shard of the fretboard has come away slightly near the nut, I informed the manufacturer and stated I could probably drop fill a slight bit of superglue to sort and they agreed best way.
a few months later and I notice the switch now won’t select one of the pickups and there’s no relief left in the neck. I slacked the rod off small increments over a few weeks but not much joy and now the rods 1/4 turn from being completely slack. (Also the nut slots were cut too low so as the E would touch the first if fretted at the third)
They agreed to take the instrument back, replaced the switch and installed a brand new neck (bolt on).
Got it back and noticed a tool indent on the 19th treble side but no big deal it doesn’t interfere with play. I waited just over a week for it to acclimate before setting the action to where I’d like it, I can’t get the treble low enough as the bridge has run out of play and now the high E chokes out on one of the higher frets.
Would you at this point allow them to rectify again or return?
thanks for listening.
the neck angle itself wrong or something or the neck twisted?
If the neck is through or set, you may be screwed.
A fret rocker tool would help to identify individual high frets.
It is possible that the neck of the unnamed guitar has an S curve or an up-ramp from the fourteenth fret towards the highest one.
Professional attention might cure the problems. Returning the guitar for a refund would be less effort.
The question is whether it can... at least without major work, ie a full fret dress.
To me, 0.5mm relief is too much, and 1mm/2mm action too low. I would start by straightening the neck to a relief of about half that, raise the bridge action until any choking stops, and check the nut height - fret each string at the third fret and look for a *tiny* gap (ideally about 1/4 of the string diameter, or less - but there must be one) between the string and the first fret.
Intonation and tuning problems sound like the nut might be too high or badly cut - or both - to me.
Either way, if this isn't something you can do yourself or get done fairly cheaply and/or at the shop's expense, I would try to return it.
They’ve asked that I leave the relief set where it is as that’s their preferred spec. They want me to monitor for movement until the new year then send it back for a fret dress. They are clearly trying to do the right thing and I appreciate it greatly it’s just a faff. For five months the guitar was great then bits started going wrong.
At this stage, it would help to know the material from which the nut is made and whether the string slots are cut more or less parallel (like a Fender) or splayed at various angles (like most Gibsons). Also, are any string locking devices involved?
tune it so open strings are in tune with tuner, play Emaj and it’s out of tune. Play a F# power chord on the 9th fret and it’s in tune?
That's the nut too high or something wrong with the grooves, or - very outside chance - the nut is fitted in the wrong place. (This is something you're only likely to find on things like 70s Martins normally, but perhaps isn't impossible.)
