I can't see the bare wire in the multicore switch cable - if it's not connected to ground the guitar will be very noisy. It needs to go to the same terminal as the green wire. It's a good idea to shorten all the coloured cores of the switch cable to as short as possible as well, that significantly reduces noise even when the shield is connected.
cheers mate
