Electro Nylon Issues
Can proximity to a TV affect the sound of an acoustic or electro nylon.  My new Roland amp is just under my TV and the electro nylon I use cuts out after a while playing, yet there is no problem if moved away from TV. Anyone else had this with a guitar Thanks
  • ICBMICBM Frets: 73027
    Is the amp getting hot?
  • tonyrathtonyrath Frets: 51
    No just tested guitar on 3 different Roland's away from TV fine
  • MDKVMDKV Frets: 56
    I would have thought you'd be getting additional noise from the TV but it's odd it's cutting out! Tried fresh batteries?
  • FretwiredFretwired Frets: 24602
    edited July 2014
    Tony .. your battery needs changing ... :-)
    Alternatively dodgy lead or damaged plug socket.
    Have you tried the actual one that's cutting out elsewhere?
    If the same one works fine elsewhere then it's either getting hot under the TV or it's picking up some sort of interference which is overloading something in it.
