I want to get the George L Cable kit but it doesn't come with a cutter, after watching Gigrig's video he used the cutter from Lava Cables, is there anyway you can get that cutter separately on its own?
Also, my google skills failed me again that i can't find any George L plugs on its own either, in total I will need 20 plugs. The kit comes with 10 so I need 10 more.
In an ideal world I would get the George L plugs to go with Lava cable and cutter so it fits...
If you have a spare cutter then I like to buy one off of you if you don't mind. I can then source the Lava cable and the plugs separately.
I didn't know they do one ! My mistake...
I like the stripping nature of the Lava cutter that's all.
For stripping you can either use any old stripper that happens to fit (I use a Wilkinsons one that cost very little indeed).
use klotz or... Whatever the other main cable brand is. I also use proper soldered neutrik plugs, and they're fantastic. I have to admit, the corner plugs are not the smallest, though.
Football is rubbish.
I know, but i am telling myself it is a small percentage of the cost of the who set up....
I am trying to stay away from soldered plugs purely because
1 - I suck at soldering, tried it once making HiFi interconnectors, it was a success but it took me hours to do 2 cables (4 plugs).
2 - I lost that soldering iron long ago and don't want to buy another one
3 - I suck at soldering.
I like the look of the lava stripper mainly after that vidoe of Dan at Gigrig for Ed. It seems a million miles easier to do than soldering 20 plugs.
http://www.amazon.co.uk/Behringer-6-In-1-CT100-Cable-Tester/dp/B000CCIVCA/ref=cm_cr_pr_product_top
Will this work? or is there one you recommend ?
Thanks
Not sure if it'll fit your connectors though.
If I was starting again with making up some pedal board leads I'd check these versions out. They're smaller than anything else and apparently very easy to put together. I use the older lava plugs and they certainly give you very sore fingers and can be a bit of a headache to get the board done in an evening! But they do work well!
