need some order help please....
bigdawgbigdawg Frets: 51
Trying to work out the order of the following pedals if anyone can advise please:
- line 6 wireless receiver
- Korg Tuner
- Clyde Wah
- OCD
- Tubescreamer
- 69 fuzz
- Joyo ACtone
- Hall of fame reverb
- black label chorus
- TC delay
At the moment the chorus delay and reverb are going into the effects loop, but I was now thinking about putting it all in front of the amp as Im fed up with the spaghetti junction of cables, but bypassing it with a bypass pedal when theyre not in use.
ta
  • bigdawgbigdawg Frets: 51
    no one..??
  • HeartfeltdawnHeartfeltdawn Frets: 23195
    Why would you bother to bypass pedals when you're using a wireless receiver?
    I don't see what your problem is. You want to get rid of a load of cables, fine. Stick everything in front. Spritz around with the OD pedals to find the combinations you like. Bang. Simple.
  • therose789therose789 Frets: 467
    I tend to use my TS to push my main drive to get a bit more grit from it so IMO i would put the TS infront of your main drive
  • capo4thcapo4th Frets: 4437
    I prefer verb after delay
