Just set the string heights to get progressively slightly higher from 1st to 6th string when measured at the 12th fret. Put a capo at the first fret if you like to eliminate any differences in nut slot heights.
If you draw this out as a cross-section you should see why the string radius needs to be about 25% larger than the fingerboard.
