EMG wiring question.
fretmeisterfretmeister Frets: 24279
I have the EMG BQC System in my sandberg. It's a 4 knob set up like an active jazz.
Volume
Balance
Stacked mid / freq
Stacked treble / bass.
I'm currently wearing a finger splint on my middle finger and when I play with a pick (the only way I can at the moment) and the splint hits the Volume control.
So I'm thinking of removing the mid control stack (which I don't use a lot) and shifting the Vol and Balance down a hole each leaving the top hole empty.
I know EMG systems are designed to be modular BUT does anyone know if it is that easy? Looking at the EMG website the individual stacked Treble / Bass control looks very different to the one that comes with the BQC system. The Mid / Freq control has a large circuit board. I am wondering if that board houses the brains in the system.
BQC System
BTC Control
You can see that the BTC is different from the bass/treb stack in the top picture (the smaller of the stacked ones.
I don't mind buying the BTC if I have to, but if I can save the money then that's better.
ta.
  • FunkfingersFunkfingers Frets: 14430
    You suppose correctly. The large PCB of the BQC houses all of the EQ circuitry.
    I suggest that you play on a different portion of the strings until your injury is fully healed.
  • ICBMICBM Frets: 72352
    Is there room in the cavity to just tuck the spare control in the bottom? Wrap it in paper to stop it shorting on anything.
  • fretmeisterfretmeister Frets: 24279
    That is estimated to be a year to 18 months and only then will I know if I can play with fingers again.
    Bit long a time period to put up with not playing how I want (which is still not playing how I really want!)
    It was a bit tight fitting it all in but I'll have a look at that.
