TL;DR: Bought a cheap damaged guitar for a lockdown project. Fixed it too quickly and need some opinions on what to do with it outside of a pickup change.
It arrived with the pickup screws threaded and a big ding on one of the horns. I managed to extract and replace the screws and because the ding was on a clear lacquer natural wood part of the horn just sanding it down and oiling it took it to "only notice it if you look for it" status. The big problem was I wanted it as a lockdown project and given that it was 1/3rd of the price I thought "damaged" meant more than 15 mins of work to getting it back to almost new. So it's time for mods.
Pickups: After considering the usual 8 string candidates (Fishman, SD, BKP) I ended up emailing Mike at Gemini Pickups and with his help decided on a set of Gemini Nemesis -
https://www.geminipickups.co.uk/7-8-string-humbucker/nemesis I will be putting push pull vol/tone knobs in for coil tapping. I'm really excited about these. Not only are they made to order pickups but I can support a small business during lockdown, which is always good.
This is where I need some opinions. What else can I do to it?
I think for me, the answer would have to be "learn to play it"...
The only thing that really occurs to me is that the front strap button mounting looks extremely dodgy - there's nothing to stop the screw being bent sideways, which could well snap it off, and the horn is thin enough that into endgrain, splitting the wood is a possibility too. I'd be inclined to fill and touch up the hole, and move the button to the back roughly where the 12th fret is pointing.
Feedback
Bass, treble volume
I reckon you need a lot more control with ERGs
There is a genuine risk of something bad happening if it has the size of screw I think it does. Most accidents I see with instruments falling off the strap and getting damaged are actually to do with undersized screws pulling out of the wood than with straps coming off buttons, these days - most people know to use straplocks or rubber washers.
