Warmoth Vs UK body builders
JetfireJetfire Frets: 1702
edited February 2021 in Guitar
In an idle 5 minutes or pure boredom, I specced up a Swamp ash, hard tailed, clear coated strat body, on Warmoth.  Total price is $230 which is proper money is around £230 including postage. Specced up something similar (I believe) with 1 piece swamp as in the UK and it came in at around £300. The only thing I can think of it that the body may not be a single piece.
Am I missing something? Obviously, buying British blah blah but potential saving of around £70, you would...
(Of course, there potentially/probably will be customs on top of that but...)
EDIT: yes, I did miss something.
  • WezVWezV Frets: 16981
    assume there will be customs.   Price suddenly becomes a lot more comparable, but there will be a lot less profit for the UK builder as he wont be buying wood in the quantities used by Warmoth, or getting the same return on his tool costs
    I have nothing against Warmoth, they were the only reasonable option for a long time
  • Clear coating adds about $180 at Warmoth so I think you have missed a click somewhere. A basic ash strat body, no finish is $280 with postage as far as I can tell.
  • JetfireJetfire Frets: 1702
    under the option for finish I have selected clear thou?
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    I do hard tail 2 piece swamp ash bodies for £380 to your door (U.K. or Ireland). That’s including a grain fill, paint finish or just the clear coat (if that’s what you want).
    I’m not touting for business btw, just giving you a number to work with.
  • Look again ;)
  • darcymdarcym Frets: 1303
    the Warmoth stuff I've had in the past has been much better value and much more specific detail available (eg: one piece body)
    Doesn't mean they don't need 'finishing' as part of your build, but the quality of the output has been better than anything I've found in the UK.
    don't forget your import fee's but Warmoth is really knocking out good stuff and they have good quality control (I had a neck fail quality control before it shipped, I was informed and the item was re-specc'd with a free ugprade).
  • DodgeDodge Frets: 1466
    I really like Warmoth stuff - I have.  I bought a swamp ash bodied thinline Tele with a Goncalo Alves neck assembled by @Twinfan and I was so enanoured with it, I built a matching Strat, another thinline Tele with a Koa on mahogany body and a koa neck with ebony fretboard.  I also built a dinky jazz bass - walnut body, wenge neck.
    I wish they'd dress the frets on their necks - but other than that I can't complain about the quality at all.  What I like is the choice of woods they offer.  I don't know of anyone else who offers such a wide variety.
  • prowlaprowla Frets: 5011
    I've got a Warmoth neck on a Strat and a Warmoth body on a Jazz; they are both simply excellent and I tend to view Warmoth as the top of the tree. They are also Fender-licensed parts.
    I've never looked at a UK retail part and thought "I must have that". (But I'm happy to be convinced otherwise.)
    Look again ;)
    Ooh, youre SO cryptic!
    So I had a revisit, you select the finish and THEN, you need to specify front and back.
    So, @GoldenEraGuitars cost is actually similar to the Warmoth one.
  • @GSPBASSES makes some top notch stuff, and price wise he's very reasonable i think.
    True indeed!
  • No doubt Warmoth do nice parts.
    you would need to check you are comparing eggs with eggs so to speak in terms of number of body pieces. As that will bump the price.
    Also swamp ash has risen in price over recent times and also as it’s an imported wood will cost more as it will go through the importer wholsealer route. Where as Warmoth I would imagine are buying directly from the saw mill.
    if you are looking for Swamp Ash to be lighter weight I would certainly ask that as a question from whoever you buy from as I have seen A lot more heavier swamp ash around than some of the feather stuff of say 5 years ago when you could get a 2lb strat body out of a single one piece board.
    I would also say in the current climate negotiate a good deal with a Uk supplier.
  • StevepageStevepage Frets: 3099
    I got a lovely Warmoth neck and body last year. One piece swamp ash with a really nice book matched quilt top. I think that came in around £350 but was unfinished because I was oiling the body myself.
  • Philly_QPhilly_Q Frets: 23730
    I'm not trying to push you in either direction as regards "Warmoth vs UK builders", but Warmoth do offer an excellent service.
    A custom order is relatively expensive, if you want any non-standard features, and they still don't give certain options (e.g. specifying a lightweight body blank).  However, if you can find something already in stock it will be cheaper than a custom order - especially if it's already finished - and the body you see in the picture will be the one you receive, and the description will be accurate.
    Their "in stock" section is nowhere near as well-stocked as it used to be, but if you want a Strat or a Tele there's still a pretty wide choice.
    None of which is to say there aren't UK builders who can provide something just as good, and you may prefer to buy British...
    I remember that guitar! :)
    This was unfortunately because they were so far behind with custom orders due to their lockdown back in March (Luckily my order was put in February)
  • LoobsLoobs Frets: 3853
    Go on lad
  • GizmoGizmo Frets: 1105
    Rosted or Shou Sugi Ban?
    It's had a bit of a tweak since - now sporting some rather tasty Gold Foils from @Mojopickups
    Here it is with the other two:
    Is that a baritone strat? It's beautiful!!!
    No - regular scale length.
    Here's the bass I put together:
