Do not use the heat gun method on anything acoustic!! Also be wary of sanding through veneers if its laminate.
Oil and wax on a spruce soundboard can deaden it a bit, at least for a while. It should liven up again eventually though, just don't be surprised if it sounds dull for a bit. Think it might be the high resin content of spruce slowing the cure of the oil, or something like that
Instagram
