Grounding Wire Gibson
Hi. Just a quick one. I snapped the ground wire on a Firebird project. Consequently it’s now too short. A bit of research suggests it’s just this stuff that they use?
0.8mm (20 Gauge) x 6m Silver Plated Non-Tarnish Craft Wire for Jewellery, Wire Wrapping, Sculpting, Hobby Craft, Wire Modelling https://www.amazon.co.uk/dp/B016KQ9U1C/ref=cm_sw_r_cp_api_i_4PC94K30824N688CKGH8?_encoding=UTF8&psc=1
Can anyone confirm please?
Thanks in advance.
Previously known as stevebrum
  • ICBMICBM Frets: 73240
    Just use a piece of a G string.
  • IamnobodyIamnobody Frets: 6944
    Good shout. Will that do as a permanent measure? Thanks
  • WezVWezV Frets: 17027
    It just needs to be a conductive link between the strings and the pot... I usually use whatever spare  wire I have closest at hand.
    Yes.
    I don't actually use that though, I use bare copper wire from household (ie wall) electrical cable. It's thicker so it produces a tighter compression between the wall of the hole and the post insert, and it's easier to bend into place in the control cavity.
    Thanks - this’ll be coming out through the old post hole and be trapped/screwed under the vibrola.
