https://www.ebay.co.uk/itm/Draper-18V-Cordless-Rotary-Drill-Driver-with-Ni-MH-Battery-83576-/143200191640?_trksid=p2349624.m46890.l49292
https://www.ebay.co.uk/itm/Draper-75-Piece-Drill-Screwdriver-Bits-Set-Power-Hand-Accessories-Masonry-HSS-/353376578729?_trksid=p2349624.m46890.l49292
It will be fairly difficult to get accurate holes in a maple neck with cheap equipment and little experience.
I drilled out the tuner holes on a neck. Opening them up from 8 to 10mm. The results were not the best
Drilling for tuners has to be square on, and really needs a drill press.
Trying to do either with no experience of drilling is a recipe for disaster. Find someone local to do it for you.
I have a logo coming too as a Fender Neck is being removed..Maybe I am being daft wanting it still to have Fender on there..Long Story,but replacing it is simpler,plus I am fed up with taking the neck off to adjust the truss rod..The neck at present is very unstable,just having headstock truss rod access will be a luxury..I have battled with this guitar moving all over the place for years.Most of my other huitars are pretty syable now I run a dehumidifier apart from in Winter...Putting a Logo on there looks like a lot of spraying lacquer and leaving it and a lot of sanding,actually a lot of work..maybe not that cheap for a guitar tech to do that work..The Logo is coming from Portugal some time between January 21st and March 21st..lol...I hope it Arrives..
This is best with a Tech I think..
