If that doesn't work, you may need to use epoxy - the high-strength, slow-set type. You need to glue them in with the studs fully screwed into them and a small amount of grease in the bottom end of them, so the glue isn't forced up inside the threads and then stops the posts being screwed in far enough.
Instagram
Both - long grain one side and shattered on the other. There’s also a piece missing... I don’t know how he did it, it’s right in the middle of the shaft! I assumed it would break down near the blade - clearly not made by Gibson
I suppose it could be glued and splinted, but not worth the bother - I just re-necked it with an old steel tube mop handle
Bandcamp
Spotify, Apple et al
