Looking for a bit of advice here gents. I’ve got a Vintage VS6 that’s a bit of a beater but an outstanding sounding and playing guitar, with one issue that I can’t figure out.
The 16th fret on the high E string chokes hugely when playing - and ONLY that note. Beautiful low action with zero choking at every other note on the neck including the 15th and 17th, with smooth bends right up to the highest fret, but 16th fret is just dead. Not just for bending but for normal fretting. 16th fret on every other string is perfect.
Guitar has had a fret level and I can’t detect any high frets - there’s no rocking. I’m no stranger at all to guitar setups but this is something I’ve not encountered before!
Any ideas what this may be?
The neck could have a ramp, twist or S curve.
The string could have a kink in it or a flat spot where it touches the fret crown.
If you bend the E to the same position as the B, but the B sounds fine there, it has to be the E string or possibly the bridge saddle, but it would be unusual for that to so specifically affect one fret position.
The only thing that makes it go away is raising the action at the bridge quite a bit but that ruins the outstanding playability on every other fret...it’s weird.
I'd take a guess that a 16th is a tiny fraction too low, so it buzzes on the 17th - Or - the 17th is slightly too high, so that it causes a problem with the 16th, but the 15th has just a bit more take off to miss the high fret.
Do you have a set of feeler gauges? that would help comparing gaps under strings and finding a low or high fret.
The 16th could have a slight dip in it or the crown is too flat and angled slightly towards the bridge, it's hard to be sure.
The fretting does look a bit ropey in general though.
I’ll try a bit of a recrown on the 16th fret, hopefully that’ll work!
