The problem is with older unregulated supplies where the correct voltage is only produced when enough current is being drawn, and drawing less results in the voltage being higher, by up to about 50% in extreme cases - it’s the high voltage which is then the risk to the pedal, not the current capacity itself.
There is a more hidden danger with very high-current supplies too, which is that they can be capable of overriding the reverse-voltage protection if it’s just done with a single diode - a lot of pedals are. So make *certain* that the supply is the right polarity, and turn off immediately if the pedal doesn’t seem to power up normally. If it does, it’s correct.
