I've looked at schematic and if it didn't have high voltage I think a transformer would be easy to find but the 350V might be the stumbling block
Yes please check the spec on the Avt
I can do it myself if it works, I do like the amp, pretty decent sound for hybrid
A worst-case option would be to use a normal 100W solid-state amp transformer for the main supply and a separate small one for the valves, like a little valve radio one - but better to do it all with one if it’s possible.
Amp has 2 ecc83's which heaters run off 38v rail
I'm hoping to get 1 transformer which can save the amp
So I've calculated 27-0-27 with 0-250 in order to get correct voltage when rectified
If can't be obtained the 2 transformers may be a solution, a mate has gave me an old HH transformer but it's a bit high 38-0-38 unrectified so would be 47-0-47 bridged
The one you want is a VS100R transformer - that has a separate HT winding. Typically for Marshall, no voltages are given on the schematic, but going by the cap ratings the LT must be under 50V and the HT at least 250V.
Of course, I don't have a transformer as VS100s are less prone to terminal catastrophic failure and are worth fixing...
Need me thinking cap on now
