I could do with another drive pedal for playing in to clean and cleanish amps.
I have a couple of boost pedals spare so I can push a light/mid gain into higher gain when necessary.
I'd like a pedal that can either give a tweedy or vox low/mid gain and/or a plexi mid gain so I can boost either.
I was looking at either the revival drive or iridium that I think both can do exactly this - the revival might sound a little better but needs more thought rather than quick tweaks, the iridium will be faster to setup and has IR's so I can go direct when that is needed.
I'm torn - be great to have room for both Has anyone got experience with using these care to chip or maybe suggest any alternatives - I did like the magma drive and the new CM plexiranger but not enough gain and maybe not flexible enough.
I’d run the iridium with the cab sim but then have the option to turn them on if I needed to go direct at any time. I need to investigate how it sounds bypassing the ir with a real cab.
I've yet to come across a Dual Overdrive that is more flexible than the Sunset given all the routing and preset options plus the built-in noise gate if needed.
Edit: if you're after preamp style, you could always consider 2 preamp pedals and a Boss LS2
