Recommendations for a single or dual channel mic preamp around £500 or under?
What would you suggest as a mic preamp for vocals in the £500 or less range?
Cheers.
cam f
  • digitalkettledigitalkettle Frets: 3354
    edited March 2021
    I've got a FMR RNP 'really nice preamp' and RNC 'really nice compressor' that I could be persuaded to part with...also got a custom 1U strip for racking them which I'd throw in. Have a Google and drop me a PM if you're interested.
    You'd have a two channel mic pre and comp and have plenty of change from your budget.
  • camfcamf Frets: 1195
    Interesting! Someone local to me might have a Focusrite ISA One for sake that I’d been pondering but I’ll check out the RNP & RNC.
  • I would suggest Focusrite ISA one. Great preamp and di. Plus you can treat them as separate channels. Add to that the direct monitoring it gives you a lot of options.
  • StuckfastStuckfast Frets: 2431
    DAV BG1.
  • octatonicoctatonic Frets: 33904
    Stuckfast said:
    DAV BG1.
    Yep, this.
    Not much of a fan of the ISA One btw.
  • I’ve found the Black lion Audio B173 is an excellent preamp for vocals.
    These are all great suggestions. I'm going to check out all of these. Thanks guys.
  • thermionicthermionic Frets: 9745
    edited April 2021
    Worth checking out some reviews of the Art Pro MPA II.
    Cheers. It looks good too.
  • CirrusCirrus Frets: 8497
    The ISA One is a solid pre, but it's a bit boring if you want it to do something. The impedance options are nice & useful in some circumstances.
    I've been pleased with the GAP Pre I got last year. There's a few different versions about and they're not all equal in terms of build quality or components, so it's worth doing some reading. And obviously their online reputation will be a bit clouded by the way they can be directly compared to Neve preamps which go for vastly greater sums.
  • jamesguitarjamesguitar Frets: 155
    Warm Audio Tonebeast (or WA12 if you want to pay a little less).
