The nut slot is wide enough,when string bending a click is heard..
When I get near the nut string bending it is really quite loud..
This is on the G string on one of my Strats,but I have another it is on the D string,another Strat..
When I check the slot by moving the string across it,,it feels like there is a ridge on the bottom of the nut slot..
This is on the G string,I haven't checked the D on the other Strat for this..
I have nut files but the slots are the perfect height..
I'm thinking maybe a bit of Wet and Dry paper,but how to keep a shape in it..
A nut file and Wet and Dry perhaps..
I'm sure there must be a quick and simple way..
You might get lucky and it only take s a swipe. If it does go too low try the baking powder and superglue trick
Instagram
I’ve had some success fixing this, when you neither want to make the groove deeper or replace the nut (eg on a vintage guitar where it’s original) by carefully scraping the centre ridge off with a scalpel blade moved from side to side.
