Knuckle shuffle
drpbierdrpbier Frets: 226
My teacher wants me to focus on maintaining the bend in the last knuckle on my fretting hand. I find this hard, especially on my little finger and especially on the low E string. Any good exercises people can recommend to help with this?
  • vizviz Frets: 10694
    Don’t think I’ve ever bent the low E with my little finger, but I guess if you press the other fingers to it so all 4 are acting as one and then pull the string towards the A string you should be able to hold it there
  • drpbierdrpbier Frets: 226
    Sorry, I might not have described what I'm after very well. I need to maintain the 'arch' in my fretting fingers, and not let them flatten out, to allow more precise fretting and better pull-offs. My habit is to let them straighten out, especially when stretching for a note. Does that make more sense?
    Ah, sorry yes, misunderstood the word “bend”. Yep, maintaining the arch while still remaining totally relaxed is something players of many diverse instruments work on their whole lives!
    One of the key things is maintaining a very loose wrist and not being afraid to let your arm move, loosely, to help those stretches. You can’t grow your fingers in length so let your hand position help you not hinder you.
    Then it’s all about practising and letting the muscles strengthen. But not in a body-builder way, rather more in a ballet dancer way :)
    You can try keeping your thumb in contact with the neck and keep your elbow closer to the side of your body (at the dusty end of the neck)
  • You can try keeping your thumb in contact with the neck and keep your elbow closer to the side of your body (at the dusty end of the neck)
    On a related note, practice in front of a mirror...if stuff looks awkward, that could be an indication for an area of improvement.
    Here's an exercise that came to mind (it's for string skipping actually!):
    https://i.imgur.com/MgY9fy9.png
    Source:
  • Here's another mindless exercise (one I wrote this time):
    https://i.imgur.com/mNVoRSw.png
    I use this primarily as a right-hand warm-up but your fretting has to be in shape to keep it clean!
