Graham (GSP) is finishing a b-stock SG for me, it's all mahogany.....Id like it to be a gold top with natural sides and back...how would you achieve this finish?
There is obviously no binding top separate the top from the sides....
Im thinking (using Nitro) build up several coats of clear all over, mask the sides and back, spray the gold, seal with more clear.....will I be able to mask a nice crisp edge?
I could just spray the whole thing gold, or just the body, but I would really like just the top to be gold....
A slightly off the wall idea is an aluminium top plate, to cover the whole top, sprayed gold nitro....I have some 1.5mm aluminium.....the rest natural...
Budget dictates I’ll have to do it myself....
Thoughts?
Stranger from another planet welcome to our hole - Just strap on your guitar and we'll play some rock 'n' roll
But yeah, lay down your sealer coats and its just a case of masking and the scraping a clean line. I did just do it on my blackburst fanned frets with a bevelled top.... I left the bevels natural on that
Tape type makes a bit difference to how much you will need to scrape
Instagram
The aluminium top plate idea is quite interesting - a bit Zematis-like. I would definitely not paint it gold, it will wear through in no time. If you could get gold-anodized aluminium sheet that would work though.
In the words of Steve Marriot, all or nothing.
Instagram
I did my junior like this:
(formerly miserneil)
https://i.imgur.com/8YaSL35.jpg
Edit
I can see it being all gold!
But all gold ftw.
