- what's your definition of "regular rock stuff"?
- what amp are you playing through and how is it voiced?
- how does your guitar sound naturally? Is it really dark-sounding and wouldn't like a similarly dark pickup, or is it thin and needs a warmer pickup to balance it out?
- what are the stock single coil pickups like, in terms of voice and output? You'll need to consider whether you want the humbucker to balance with them or if you're happy for your bridge sound to give you a kick compared to the neck/middle.
Full-size vs SC-size is personal choice - a factor might be whether the guitar is routed for a full size humbucker already and whether or not you want to modify your scratchplate or get a new one to accomodate a humbucker. If not, then the SC-size has an obvious advantage. They do sound different though, and that's not to everyone's taste, and there are fewer SC-size humbuckers available than there are full-size.
Yes, almost anything will work with the S1 switch - it's an incredibly capable switching device - but wiring them up is a nightmare and most likely best left to a professional, as they're very complicated compare to your "standard" switch or push-pull. But yes, provided you get a 4-conductor wired humbucker, a split or tap should be possible.
If you do want to use a full-size humbucker then you may want a different switching setup with the S1, and then it becomes quite complicated.
The second question is how much of a volume difference are you willing to accept between the stock single coils and your chosen upgrade? (If your neck and centre pickups read c. 6.0k Ohms, a bridge pickup of 9 to 12k would balance pretty nicely without coil splittage.) From the Seymour Duncan range, you are looking at the Red Devil and Li'l Screamin' Demon. DiMarzio does some nice "Rails" pickups too.
Some replacement pickups are fussy about the volume pot resistance value.
Secondly establish what you actually use the S1 switch for
Thirdly either: wire a hot rails in its all you need or buy ready wired HSS scratch plate wire it in and use it .
Forthly go back to original configuration and buy another HSS or HH guitar
If you wanted to keep SSS, I’ve got a Seymour Duncan Lil Screamin Demon in my parts box that’s an easy low cost option. It balances a bit better than a full size humbucker typically would, but the flip side is it’s not quite the same sound. They do pick up harmonics well and are very quiet even with a lot of gain, but they don’t cover the same amount of area under the strings so will never sound quite the same.
I’ve been down this rabbit hole and ended up sticking with single coils and having other guitars for other sounds.
i have a couple of other bridge humbucker guitars but absolutely love this strat so want to try it with a bit more beef in the bridge
I had a Fender Sienna Sunburst Ash HSS S1 Strat c10 years ago for a while which in hindsight, I wish I had kept long term. Playing back to back against a LP Standard and Cu 22, they all had their own tone, there is a substantive difference.
You can also achieve a nice rock/distorted tone just using hotter single coils and the right fx+eq pedals.
Want a cheap but good single coil sized humbucker to try then iron gear punch well above their weight and price.
https://www.axetec.co.uk/guitar_parts_uk_077.htm
My favourite is the Seymour Duncan Little 59 Strat HB in a sss pickguard strat. Jeff Beck Jrs are also good, diff tone and a bit hotter.
https://www.andertons.co.uk/seymour-duncan-sl59-1b-little-59-strat-white-hum-canc-1611205-22w?utm_source=google&utm_medium=organic&utm_campaign=surfaces&gclid=Cj0KCQjwrsGCBhD1ARIsALILBYqIWP6n7CacO9wMRVlw85IufvHVkANAWGHTCM5-NRH9COKsiwXl0LIaAiuSEALw_wcB
If you want to go to a full sized humbucker then there is too much choice and personal preference really. Pole spacing can matter though. I like the seymour duncan tb-14 custom 5 trembucker in a strat for that reason.
https://www.andertons.co.uk/seymour-duncan-custom-5-trembucker-in-black
https://www.seymourduncan.com/single-product/custom-5
You won't achieve a Gibson/PRS c22 (other brands also apply) rock tone/sound though, no matter what you do as this relies on the guitars construction not just pickups.
To be clear, this doesn't mean you won't achieve the tone you want in the Strat, it's just different.
I solved this problem by having a full spectrum of SSS, HSS, HSH, HH, H guitars.
I'd prefer S S P90
or overwound SS + a HB
First thing to try is a hot rails or SC-size HB
Or to fit a mid-range boost and keep your SSS
Ebay mark7777_1
