Hi all
Tried to put what i think are Blackguard custom shop pickups in a japanese 62' bound tele. Bridge has gone in fine and is working, however the neck pickup had 3 wires coming from it which threw me, white, yellow, black. I read online that the yellow goes to switch and the white and black both go to ground, which seems odd as that would mean theres 4 wires going to ground but i did as it said, and simply get no noise from it at all.
Of course, theres always a chance that my soldering is so shite that thats the problem, but the yellow wire going to the switch seems soldered as well as the bridge pick up is so slightly confused.
The japanese electronics are different...the 3 way switch is a large white and black plastic brick rather than the usual US switch.
Any ideas please?
If you're not using a 4 or 5-way switch then the two grounds can be joined together.
Instagram
hope thats useful
In either case, all photographs of these pickups illustrate them with two conductors per pickup.
A neck/Rhythm Telecaster pickup has three conductors for one of three reasons.
1) Coil tap.
2) Coil splittage (dual coil pickups only).
3) Separating the coil and cover ground connections.
The latter is necessary for phase reversal and/or series/parallel interconnection.
If the BKP pickup has been modified in this way, swapping the white and yellow conductors should cure the problem.
Really appreciate everyones help
