Then, find a ground connection on the S1 - that will be a (usually black) wire that goes to the pot body somewhere, it doesn't matter exactly which one if there's more than one. The bare wire on the new pickup always goes there.
Finally, the remaining two wires go to where the two wires from the single coil went - one of these may be another ground connection, depending on what the S1 does in this circuit. If the bridge and middle setting with the S1 in 'normal' mode ends up thin-sounding then it's out of phase and you need to reverse these two wires.
That's it.
The 'jump'/'blower' type switch is a little more complicated but if you can manage the first two you shouldn't have too much trouble.
